I am looking for an 1/8" Collet for my 3hp Milwaukee Router. I do not want to use a bushing . Does anyone have an aftermarket source? ....Ken
Depends on what you’re chucking up and how fast you’re turning it…………
I had an old cordless drill that was headed for the garbage (I salvage anything I can and there was no power cord to cut off and keep.). I tore into it and the keyless chuck had a 1/2” shaft that went into the bearings, perfect fit into my 1/2” cullet on the PC router. I only use it for drilling holes and never turn it faster than the lowest speed on the router but I can chuck up drill bits from .032 to 3/8”.
May I ask; why don't you want to use a bushing?
I have an MCLS 1/8" Bushing and it will not secure an 1/8" router bit ..Ken
On the main shopbot website Brady's bits and pieces.. his last entry is about a 1/8" chuck. Given his recommendation, and my need for one, I bought one also and it has worked marvelously. Now I use 1/8 bits just as easily as 1/4 and 1/2.
I suggest you give it a try-
The link:
http://www.shopbottools.com/BradysTricks.htm
D
Thanks Dana, that's the way I'll go ...Brady's page is great, I look forward to sitting down and working my way through it ....Ken
Brady Watson deserves the thanks, I am just passing along his advise. Ken let us know how it goes for you.
D
The MCLS bushings don't work, but the Spellman bushings do, and are very inexpensive:
http://www.rlspellmanmfg.com/index_bushings.html
You can buy a set or individual bushings:
1/2" OD x 3/4" Long
1/16
Forgot to mention that they are also available in letter (A-Z), number (1-60) and metric sizes!
Hi Kevin: Thanks for the link ..Those bushings are an entirely different animal than the MCLS. They look like they would work well....Ken
